0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#182064 05/20/2005 7:41 PM
Junior Member
Junior Member
I have looked throught all the faq's and done my best to figure out the engine I have, but I cannot find a matching number. The only numbers I can find on the block are K19 and LAQ9676. I know from patricks catalog that the K19 number would mean that it is a 49' or 59', but I can't find any corresponding numbers. It also has 2 bolts studs through the valve cover, but the pushrod cover doesn't cover the plugs? Any help would be much appriciated.
#182065 05/21/2005 1:22 AM
X
X Offline
The K19 does look like it would be a date code, but the translation to '49 or '59 doesn't fit the serial number in this case. The LAQ serial number prefix deciphers as a 1953 powerglide-equipped 235, used in the 2100 and 2400 series cars (as per my 1953 resto pack). That would make the engine one of the first full-pressure oilers, equipped with hydraulic lifters and insert connecting rod bearings (non-babbit).
Finding the block casting number would help verify. See this thread for help locating this number.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#182066 11/19/2006 8:24 PM
I too am struggling all over the net and on this site to get it straight Surley some ome casn tell us where to look up numbers for ourselves Have a fun day
Slider
Jesus is Love! Never forget the Veteran.
AND God bless Amercia!
