1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#181947 05/23/2005 4:12 AM
I am building a semi-original '52 3100. I want to put modern rims on the truck. I have gone to several wheel shops and the look at me cross-eyed when I tell them it is '52 chevy 6 bolt pattern. Does anyone have the a source for finding rims that will fit or the measurements that can take into a wheel shop.
#181948 05/23/2005 4:22 AM
chev235,
From memory I think six lug wheels from a Toyota Landcruiser or Nissan Patrol will fit fine on the Chev six lugs.
Bob
#181949 05/23/2005 4:40 AM
Bob,
Would it matter what year of Landcruiser or Patrol?
Aaron
#181950 05/23/2005 4:56 AM
Not sure Aaron. I know that the late seventies to late eighties models are ok. I would think that later models would have the same if they were six bolt pattern. Couldn't you also take one of the Chev wheels in and get them to see which rims had the same spacing?
Bob
#181951 05/23/2005 10:57 AM
Ck with Summit racing,I think it is summitracing.com.
#181952 05/23/2005 1:41 PM
H Online: Content
Virtually all 6-bolt lugs are on the same spacing. A Chevy LUV wheel will fit a stovebolt, ditto for a Toyota Land Cruiser, etc. Some of the early Chevy Blazers had 6-lug axles, also. It sounds like you need to switch wheel shops!
#181953 05/23/2005 2:19 PM
Mine are from a 85 K-5 Blazer..15X8 all aluminum with 6lugs...5 1/2" bolt pattern, and a 3 3/4" backspace..No problems at all with clearence
#181954 05/23/2005 8:40 PM
Anonymous
Unregistered
Anonymous
Unregistered
Will the brand new 2000-2005 6 bolt chevy truck and suv wheels fit our my old 6 bolt? thanks
#181956 05/23/2005 10:59 PM
regarding the land cruiser wheels: fj60 and fj62 (1990 was the last year for the 62) have the correct backspacing and the rim is 6" wide. i'm pretty sure the fj40 has the same stock width and backspace too but i don't have one of those grin . after the fj62, the backspacing changed (will require spacers) and they went to an aluminum wheel. it's a very obvious toyota wheel too, i think it would look funny on a chevy. the 60 and 62 wheels are chrome plated steel.
iirc summit just has the generic wagon wheels in black, white or chrome.
