| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | I am building a semi-original '52 3100. I want to put modern rims on the truck. I have gone to several wheel shops and the look at me cross-eyed when I tell them it is '52 chevy 6 bolt pattern. Does anyone have the a source for finding rims that will fit or the measurements that can take into a wheel shop. | | | | | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | chev235,
From memory I think six lug wheels from a Toyota Landcruiser or Nissan Patrol will fit fine on the Chev six lugs.
Bob | | | | | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | Bob,
Would it matter what year of Landcruiser or Patrol?
Aaron | | | | | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Not sure Aaron. I know that the late seventies to late eighties models are ok. I would think that later models would have the same if they were six bolt pattern. Couldn't you also take one of the Chev wheels in and get them to see which rims had the same spacing?
Bob | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Ck with Summit racing,I think it is summitracing.com. | | | | | Joined: Feb 2004 Posts: 29,785 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,785 | Virtually all 6-bolt lugs are on the same spacing. A Chevy LUV wheel will fit a stovebolt, ditto for a Toyota Land Cruiser, etc. Some of the early Chevy Blazers had 6-lug axles, also. It sounds like you need to switch wheel shops! Jerry
| | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Mine are from a 85 K-5 Blazer..15X8 all aluminum with 6lugs...5 1/2" bolt pattern, and a 3 3/4" backspace..No problems at all with clearence | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Will the brand new 2000-2005 6 bolt chevy truck and suv wheels fit our my old 6 bolt? thanks | | | | | Joined: Feb 2005 Posts: 81 Member | | Member Joined: Feb 2005 Posts: 81 | regarding the land cruiser wheels: fj60 and fj62 (1990 was the last year for the 62) have the correct backspacing and the rim is 6" wide. i'm pretty sure the fj40 has the same stock width and backspace too but i don't have one of those  . after the fj62, the backspacing changed (will require spacers) and they went to an aluminum wheel. it's a very obvious toyota wheel too, i think it would look funny on a chevy. the 60 and 62 wheels are chrome plated steel. iirc summit just has the generic wagon wheels in black, white or chrome. | | |
