| | | Forums66 Topics128,152 Posts1,057,012 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I have an old set of Fiamm air horns missing the little compressor that goes with it. Does anyone know if airhorns can be honked with manifold vacuum? Maybe I'll just try it.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | isn't that kinda like whistleing when your breathin in?  you can get little compressors for those things at places like maybe JC Whitney, and there's compressed air cans to run the ones they use at ball games Bill | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Probably less futzing around to simply purchase a new set with the compressor.
I think you'd need to use the vacuum to run a compressor, and then you'd need to store the compressed air so your horn would work when vacuum is low.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | Go to a salvage yard, and get the air shock compressor off an old Cadillac Fleetwood. (Late 70's to mid-80's) It's already got a pressure-control switch built in, and you can use a small Freon tank as a reservoir. The control valve and air tubing for the horn can be had at any truck parts store, and you're in business! Jerry
| | | | | Joined: Feb 2002 Posts: 20 Member | | Member Joined: Feb 2002 Posts: 20 | Once upon a time I took an old air tank from a truck w/air brakes and installed a threaded air stem so I could charge it with my shop or jobsite compressor- ran a line to the pirated air horns and was in business (150 psi really makes 'em speak)
longtrail It is only possible to live happily ever after one day at a time.
