| | | Forums66 Topics128,013 Posts1,055,322 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18172 02/18/2004 3:38 AM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | All my manuals give me the "warm" valve lash specs, but they do not specify an initial "cold" lash setting. I am guessing that I should set the valves initially to the warm valve setting for now. What do you guys think?
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#18173 02/18/2004 4:30 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I would leave them slightly on the loose side of the warm setting. Leaving them a little loose won't hurt them at all. Leaving them too tight can burn out the valves or seats in short order.
#18174 02/18/2004 1:37 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Define a little loose...Say 0.002-0.004" from spec for example? Thanks.
#18175 02/18/2004 8:11 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 |
#18176 02/18/2004 11:06 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Patrick and my Howard cam card say different. They say to set .005" tighter for a new cam, cuz she'll slack up as the valvetrain breaks in. I tried setting the valves to the "hot" settings, even then it ended up sounding like a hailstorm on a tin roof. Had to go back and take up mad slack after the break-in.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#18177 02/19/2004 5:08 AM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Chiphead, I had heard/read that somewhere as well, that the clearances actually get wider as the engine heats up. At first I thought this sounded back words to me, since as metal heats up it expands, so if the cam, lifters, and rockers expand you would think they would get tighter. But if think about all the metal in the block and head from the cam up to the top of the head, which is also expanding as it is heating up, that this expansion is going to widen the clearance more than the other components are going to tightening them.
Any chance you could send me a copy of your Howard Cam Spec Card? I never received one with my Howard M4F cam I just installed. What are the valve lash specs from the Howard's card?
#18178 02/19/2004 9:18 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Sorry, I didn't realize this was with all new parts. It is bound to loosen up then. I was assuming you just replaced the head gasket or something.
Some engines do get looser as they warm, and some get tighter. I was erring on the side of conservatism.
#18179 02/19/2004 1:08 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | The Howard M4F card says hot setting .014 & .016 so .005 tighter would be .009 & .011. My experience with these settings in a rebuilt 235 was too tight and ran hot. After much fussing it ran better and cooler at .011 & .014. The .011 exhaust setting does not leave enough time for the exhaust valve to transmit heat to the head.
52pu
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#18180 02/19/2004 3:16 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Thanks for the info, I will try 52pu settings to start with, but I won't be able to start the engine for 3-4 months, since I have much to do on the rest of the truck before I can put the engine back in the truck.
#18181 02/19/2004 9:14 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | That'll work, set them cold with the lifter on the base circle of the cam. I usually set each cylinder when piston is at TDC of compression stroke. And dont be worried if starts to clatter during the 20 minute break-in. Just let it cool off some and reset to what 52pu said.
