Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (78buckshot), 43 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#181685 01/17/2005 6:27 PM
1 Offline
Fellow Stovebolters,
I need the cdl requirements clarified when "Combination Vehicles" are used.If I have a truck with a 22,000lb.GVWR to pull a trailer,what is the maximum GVWR allowable for the trailer.My interpretation is no greater than 10,001.Thoughts & opinions???
Ron
#181686 01/17/2005 6:35 PM
Anything over 18000 LBS requires a CDL B.You will also need the air brake endorsment if the truck has air brakes.
#181687 01/17/2005 6:56 PM
26,001 lbs GVW requires a CDL.
Easiest thing is to contact your state licensing authority and ask.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
