1 members (walterhvogel), 87 guests, and 3 robots.
Topics128,035
Posts1,055,559
#181444 02/16/2005 4:11 AM
Junior Member
Junior Member
hi,
ive got a 55 2nd series 3100 truck. i am replacing the cab with a 58. can someone tell me where the cab mounting bolts are, and if they are in the same location on the 58? thanks for the help
clark
#181445 02/16/2005 7:53 AM
55-59 cabs are identical, except the 58 cab has slightly different hood mounting eek the mount holes on the 55 hinges can be modified a bit to work, but expect some struggling to fit the hood
mount points [4] should be obvious - front= pass right foot, drivers left foot, back ones about 8-12" from rear of cab outside of frame - steering column has to be removed and stowed b4 liftoff grin
