0 members (),
80
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | If your FIL is in town, ask him if THIS is the truck he saw.. Thats the pic I took of it when I went to look at it when it was in the paper, and the same truck that's sitting out at that guys shop now on the main drag thru Minitare.
| | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Fumblin,
Yep, he says that's the one! | | | | | Joined: Aug 2005 Posts: 23 Member | | Member Joined: Aug 2005 Posts: 23 | Could it posibaly be a chevy ute?
JJ
JJ
| | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | Here is an ebay ad for a 1937 Terraplane Utility Coupe article. This is what Hudson produced. Chevy made a similar-style coupe, as well. http://cgi.ebay.com/ebaymotors/1937...5025QQcategoryZ42606QQrdZ1QQcmdZViewItem
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | The thing in the gully had headlights mounted on the fenders.
JJ
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I think it was established, based on what the dash cluster looked like, and what can be seen of the front that the vehicle was/is a '39 Chevrolet two door coupe. That looks like this body style
