3 members (Southerntruck, fonz8261, Hotrod Lincoln), 157 guests, and 0 robots.
Topics128,113
Posts1,056,279
Members48,439
Page 2 of 2 1 2
If your FIL is in town, ask him
if THIS is the truck he saw..
Thats the pic I took of it when I went to look at it when it was in the paper, and the same truck that's sitting out at that guys shop now on the main drag thru Minitare.
Jed Offline
Fumblin,
Yep, he says that's the one!
Could it posibaly be a chevy ute?
JJ
The car/ truck
JJ
Here is an ebay ad for a 1937 Terraplane Utility Coupe article. This is what Hudson produced. Chevy made a similar-style coupe, as well.
http://cgi.ebay.com/ebaymotors/1937...5025QQcategoryZ42606QQrdZ1QQcmdZViewItem
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
The thing in the gully had headlights mounted on the fenders.
JJ
Or here is a page onstove bolt with fender mounted headlights in on utes
http://www.stovebolt.com/techtips/history/holden.htm
JJ
I think it was established, based on what the dash cluster looked like, and what can be seen of the front that the vehicle was/is a '39 Chevrolet two door coupe.
That looks like this body style
Page 2 of 2 1 2
