5 members (Bill Hanlon, Joe H, Jon G, baldeagle, Nick in Manitou), 46 guests, and 2 robots.
Topics128,014
Posts1,055,333
Members48,419
#181285 04/22/2005 8:07 PM
Junior Member
Junior Member
hi,
ive got a 55 chevy 2nd series pickup. ive got to change cabs because the current one is rusted away. in order to change the cab i need to remove the steering column, what is the easiest way to do this? thank you for your advice.
clark
#181286 04/22/2005 8:41 PM
remove the wheel and shifter [if column shift] and wire connections at dash, unbolt it from the dash, unbolt it down on the frame - remove from below - pretty easy except for weaseling it out, which isn't hard if engines out and trucks up in the front
