| | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 12 Junior Member | | Junior Member Joined: Jan 2005 Posts: 12 | hi, ive got a 55 chevy 2nd series pickup. ive got to change cabs because the current one is rusted away. in order to change the cab i need to remove the steering column, what is the easiest way to do this? thank you for your advice.
clark | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | remove the wheel and shifter [if column shift] and wire connections at dash, unbolt it from the dash, unbolt it down on the frame - remove from below - pretty easy except for weaseling it out, which isn't hard if engines out and trucks up in the front
Bill | | |
