5 members (dbwr, MickeyP, Gdads51, Steelonsteel, 1 invisible), 22 guests, and 8 robots.
Topics128,013
Posts1,055,312
Members48,419
#18109 02/25/2004 5:34 PM
1 Offline
Whats the best radiator out there for 50' half ton with a 235. I really like those brass top ones cool
1950 1/2 ton 3 window
#18110 02/25/2004 10:15 PM
Here's a little heads-up on that- - - - -they're all brass top, just strip the paint off, and polish the existing top tank!
#18111 02/25/2004 10:31 PM
I polished my brass top a while back - looked great until the tarnish returned.
What's a good way to re-polish the Brass without making a mess on my clean engine?
Could I clearcoat the brass after polishing?
thanx....
#18112 02/26/2004 12:09 AM
Brass tank top? Hey, I should do this to my Harrison rad. Yes I think you could infact you maybe a high temp clear coat to keep it shinny.
Craig
#18113 02/26/2004 12:15 AM
1 Offline
I've tried clear coat on exposed metal surfaces, it looks nice for a while, but with heat, it tends to yellow.
#18114 02/26/2004 4:19 AM
Eastwood makes a high temp clear coat called "Diamond Clear" and they say it is "Gloss Clear For Bare Metal Surfaces and is Fuel Resistant, Heat resistant to 350F, and Non-Yellowing Formulation" This may do the job. I purchased this Diamond Clear to coat my Offenhauser Intake manifold after I bead blast it, but I have not done it yet, so I do not know just how well it is going to hold up.
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#18115 02/26/2004 5:31 AM
Hey, it's I guess it's what turns your crank, but now did the radiators leave the facory in shinning brass?
#18116 02/29/2004 9:27 AM
1 Offline
No but it looks nice grin
