| | | Forums66 Topics128,013 Posts1,055,322 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18109 02/25/2004 5:34 PM | Joined: Feb 2003 Posts: 45 Member | | Member Joined: Feb 2003 Posts: 45 | Whats the best radiator out there for 50' half ton with a 235. I really like those brass top ones
1950 1/2 ton 3 window
#18110 02/25/2004 10:15 PM | Joined: Feb 2004 Posts: 29,744 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,744 | Here's a little heads-up on that- - - - -they're all brass top, just strip the paint off, and polish the existing top tank! Jerry
#18111 02/25/2004 10:31 PM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | I polished my brass top a while back - looked great until the tarnish returned.
What's a good way to re-polish the Brass without making a mess on my clean engine?
Could I clearcoat the brass after polishing?
thanx.... | | |
#18112 02/26/2004 12:09 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Brass tank top? Hey, I should do this to my Harrison rad. Yes I think you could infact you maybe a high temp clear coat to keep it shinny.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#18113 02/26/2004 12:15 AM | Joined: Feb 2004 Posts: 28 Member | | Member Joined: Feb 2004 Posts: 28 | I've tried clear coat on exposed metal surfaces, it looks nice for a while, but with heat, it tends to yellow. | | |
#18114 02/26/2004 4:19 AM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Eastwood makes a high temp clear coat called "Diamond Clear" and they say it is "Gloss Clear For Bare Metal Surfaces and is Fuel Resistant, Heat resistant to 350F, and Non-Yellowing Formulation" This may do the job. I purchased this Diamond Clear to coat my Offenhauser Intake manifold after I bead blast it, but I have not done it yet, so I do not know just how well it is going to hold up.
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#18115 02/26/2004 5:31 AM | Joined: Nov 2003 Posts: 86 Member | | Member Joined: Nov 2003 Posts: 86 | Hey, it's I guess it's what turns your crank, but now did the radiators leave the facory in shinning brass? | | |
#18116 02/29/2004 9:27 AM | Joined: Feb 2003 Posts: 45 Member | | Member Joined: Feb 2003 Posts: 45 | No but it looks nice
