8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert), 94 guests, and 2 robots.
Topics128,052
Posts1,055,716
#181067 02/21/2005 2:27 AM
Apprentice
Apprentice
are proportioning valves needed when installing disc brake kits on a 50 chevy 3100 using a manual disc brake master cylinder? discs on front and stock hucks in the rear. --- much oblige.
rrf
#181068 02/21/2005 2:50 AM
Yes, they are required. Check out this
web page.
#181069 02/21/2005 3:03 AM
Good web page, Cletis. I used a stock combination valve out of a 1980 pickup that had discs in the front / drums in the rear.
Gord
1954 1/2 ton 235 4 speed
#181070 02/22/2005 3:41 PM
Cletis,
that is a very good link, thanks. A few months back, there was a multi issue article on brakes, in Classic Trucks or Custom Classic Trucks, where the guy stated that the 10 psi valves were to hold the shoes against the drum!!! I knew that he was out to lunch. The scary part is that there may be some rod builders out there that believe everything they read.
Fred
1951 1 Ton Completed
#181071 02/22/2005 6:04 PM
Wheather you need them or not also depends on where the master cylinder is related to the wheel cylinders. On a small street rod, the wheel cylinders can be higher than the master cylinder and thus, the fluid runs out of the cylinders back to the master. The pressure valves or check valves hold pressure in the cylinders. 10 psi is not enough to hold the shoes out if you have good springs and hardware. Just use parts from a modern truck about the same weight and you should be fine. Joe
