0 members (),
123
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18066 03/16/2003 1:39 PM | Joined: Nov 2001 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 128 | I have a 45 GMC 1/2 ton P/U with a 302 straight six and an SM-420 4-speed. The pedal cluster originally mounted directly the the drivers side 3-spd. The emergency brake mounted on the passenger side of the 3-spd. With the SM-420, there is no mounts available. What options are available to keep the original look, and under the floor mount assembly? Of couse, I also want to upgrade to a duel master cyclinder, but have that worked out. Are there off the shelf custome brackets available, anyone run into that that can send me some pics to help me resolve this?
Thanks | | |
#18067 03/16/2003 2:10 PM | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | 'Morning, F1. Hope you're well. I think I remember Tony Pascarella posting some pix awhile ago of a somewhat similar(?) mod on Joy's '51. Something to do with pedals attached to a different bellhousing. Or maybe it was his '37...can't remember for sure. You might want to try sending him a pm or an email. Shouldn't be too hard to do, you'll likely just end up making some mounting plates out of steel plate and tubing to bolt up to your new bellhousing. Hope this helps, best of luck. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
#18068 03/17/2003 4:28 PM | Joined: Feb 2003 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2003 Posts: 73 | jim carter's classic truck sells a bellhousing that may solve your problem. it's an early style bellhousing with the pedal mount that accepts later transmissions. here's a link to the catalog page: http://www.oldchevytrucks.biz/c/g8/p/041f.html | | |
