2 members (Gib70, Tronman), 117 guests, and 3 robots.
Topics128,042
Posts1,055,509
Members48,424
#18061 05/01/2002 2:51 PM
I've got a rebuilt chevy 250 with 3k on it and want to know if these oil pressure reading are acceptable: 30 psi at start-up, 8-10 psi warm idle, and 20-22 psi driving? Thanks.
#18062 05/01/2002 2:59 PM
I hope those are OK because I have about the same (or a little more) for the '53 235 in my '48.
#18063 05/02/2002 12:13 AM
Those numbers are low. My 1962 235 has 25 at idle and 50 when its going. I'd run heavy oil till I found the problem.
if it dosen't need fixed, break it
#18064 05/02/2002 12:35 AM
Those readings are low on either engine.The oil pressure at idle is too important but its nice to have at least 35 psi hot and driving down the road.If the pressure has been low and steady for a long time, and you don't ream the snot out of the engine,just drive on.A length of duct tape over the guage will lessen oil pressure anxiety syndrom
#18065 05/02/2002 5:45 AM
Tony's been watching Red Green again! grin
Fred
52 3600
69 C-10
