| | | Forums66 Topics128,012 Posts1,055,315 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 78 Member | | Member Joined: Sep 2001 Posts: 78 | I just posted a topic a few days ago but I'm still not sure what to get. I need a radiator for 1966 chevy pickup and have no idea what will work. I will have an automatic transmission. I have posted a link below. Could someone check it out and see if this is what I need. If you select chevy then radiator then 1966 then c10 then 327 it will take you to the radiators I am looking at. Do I need the three row? Sorry if this is too much trouble Thanks http://www.radiatorexpress.com/part_lookup.asp | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I check out the website you showed. It shows 2 radiators to fit your C-10 with 327. Both say they can be used with automatic or manual transmissions. Not sure why the difference in sizes. Do you not have the original to measure up? Usually 3 cores are considered to be heavy duty, good for towing, AC, ect.... Most radiators anymore come with fittings for various combinations of things and you remove the plugs that you need for your situation. Maybe another Bolter can enlighten us further. | | | | | Joined: Jul 2004 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 78 | Hi One of the radiators listed is a downflow radiator the Modine part number is 1R284 which should be correct for your truck. The radiator has tanks on the top and bottom not on the sides. That part number is a three row core. It is a good time to replace the rubber pads that hold the radiator in place. Steve | | | | | Joined: Sep 2001 Posts: 78 Member | | Member Joined: Sep 2001 Posts: 78 | Hey guys, Thanks so much. I don't have the original radiator because I am piecing it together piece by piece and it didn't have one when I bought the truck. Thanks again. If someone else checks this out and has anything to add then please do. Thanks again folks your help is greatly appreciated. Brady Eldridge | | | | | Joined: Sep 2001 Posts: 78 Member | | Member Joined: Sep 2001 Posts: 78 | Also hourhand or anyone else what is the modine part number. | | | | | Joined: Jul 2004 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 78 | Hi Sorry, Modine is a major aftermarket radiator manufacturer. Their part numbers are sort of an industry standard. Because you do not have a radiator in the truck you should take some measurments. The Radiator Express site has the core size and if you call them they can provide the overall height and width. If you need more help or info let me know. Steve | | |
