3 members (Bill Hanlon, DES57, Tom McGrath), 118 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
I would like to upgrade my front end. I have located a subframe from a Volare, but would like to keep the same wheel bolt pattern as my rear end (5 on 4 3/4). The rear end is from a 1984 Pontiac Trans Am w/ disc brakes and 3:73 Posi gears. First- Is this possible? Second- Is there any articles or directions for doing it?
The Volare type swap is more popular on Task Force (55 2nd to '59) than on AD trucks like yours. I don't know why, but I do know the frames are different.
1 Offline
Just my opinion, but if you HAVE to have power steering, disk brakes, and IFS, on the 1947-1955 first series frames, I would go with a '67-87 Chevy IFS swap, the swap is easy (I'm nearly done my second one) the difference between the frames is 5/8" on each side, parts are relitively cheap, doner trucks are easy to find (I used a '72 or newer for the power disks and power steering). If you don't need the IFS, you can upgrade your straight axel to power steering and power brakes easy enough, as I plan to do with my newly aquired '53 panel. Keep it all chevy, then you can get it aligned anywhere, parts anywhere (and usually in stock) and you can say its all chevy.
Ya but with the Mopar stuff just a turn of the bolt and down in da weeds!!No need for air bags! grin
48GMC 5window,350,700R4,p/w,p/b,and a couple of homemade parts!
41 Sedan Delivery next up to be reborn!!
"Nothing is Junk,just unfinished projects" Desert rat with a spray gun!
Hey, Oldsub, 1951COE, 48GMC pikum up and everyone else, thanks for your feedback. I have heard about others using a 72 Chevy P/U IFS. Can you give any pointers on the 1972 Chevy w/disc brake change over? Are there many modifications needed in regards to the inner fender or radiator support? It would be cool to keep the straight axel, but understand there is no way to have it handle very well. If you have an experience in regards to this type of change over, they would be greatly appreciated.
I've not performed the conversion to later IFS, I have only read about it and looked at ones others have done. I expect to do it on one of my trucks eventually.
You can have disk brakes and power steering with out performing a converstion like this one. And some will argue that your original suspension will handle nearly as good if its in good repair.
The swap is a big enough project that I'd suggest you look hard at your needs before committing to the conversion.
There are several issues with the swap.
First is that you won't be lowering the truck this way, unless you also buy dropped spindles.
Second is that the crossmember is designed to mount on a slightly wider frame, so you'll need to make sure your mounting accounts for the width and mounts everything adequately. The steering box and idler arm need to be mounted correctly too.
And the track width is a little wide. You may have trouble finding wheels that will allow mounting tires inside the wheel wells.
One last thought, the IFS is basically the same from 1963 through 1987, and a couple years more on Suburbans. In '71 disk brakes were optional, starting in '72 disks are standard. If it were me I'd look for the newest one I could find in order to have the most modern parts.
Its not really this simple, but those are the issues that occur to me right now.
HTH
heres a link ive found or was given or whatever that kind of gives a good idea and what to expect when doing the 73-87 swap
click me
I've always felt that one oversimplified...
If you do this please take lots of pictures and notes. We'll all want to learn from your experience!
Measurments are your best friend!You can never measure enough.Make sure the truck is level on all four corners as you will be taking readings off the slab.Dont forget about bracing before you cut anything loose.Make sure to check from the center of the rear axle to the center of the front hub,and cross measure from right rear to left front and vice versa.As oldsub said pictures are a big help.The radiator support can be mounted to tabes you can make after it is in.Be sure to check with the sheet metal for alignment.Me i like to leave the front sheet metal on when doing this.Hope this helps!
