2 members (Ponchogl, Hush),
67
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 65 Member | | Member Joined: Jan 2003 Posts: 65 | I've read several of the posts on this subject and heard lots of advice. Here's my problem. I remove the hood spring supports from hood (not cab) and lay them on linner fender out of the way, adjust hood to fit at cowl and fenders, reattach those supports and now the cowl fit has large uneven (from dirvers side to passenger side) gap too high and too far forward. Is this corrected by new support springs or by enlarging the hinge plate mounting surface holes? | | | | | Joined: Apr 2002 Posts: 142 Member | | Member Joined: Apr 2002 Posts: 142 | I posted awhile back about the brace on the rear of the hood itself ,in the rear ,loosen the four screws on the plate in the center rear and see if it helps from side to side. | | |
