1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#180127 04/26/2005 11:02 PM
Apprentice
Apprentice
I'm getting ready to weld the cross sills on the frame of my 57 chey step side. I have three sills two are the same and the third is flared at the ends. Where does the flared one go? One source says in the center and another says inbetween the center and rear.
#180128 04/27/2005 1:24 AM
actually there's 4, + the very front and very back - the middle 2 are thinner than the other 2, as they go in the area where the frame kicks up - and I hope you're not welding them to the frame of the truck eek they bolt to the bed wood and box, then the whole unit bolts to the frame
#180129 04/27/2005 2:17 AM
Apprentice
Apprentice
Hey Thanks
When I took it apart they were welded to the frame, but this truck had been hacked up. There is some pads that came with the new sills should they be welded to the frame or does it matter they bolt on as well?
#180130 04/27/2005 3:09 AM
eek folks do any old thing to keep'em workin! grin
if by pads you mean thick square washer sorta things, they're just shims to seat it fairly level, and may not even be necessary - may be some rubber pads too that sit on the frame to stop body squeek, but the only part welded is the rearmost sill below the gate that gets fixed to the stake pocket boxes there, and maybe the frontmost one, tho' I forgit just now, and my assembly manual is on loan - that's a handy book if you can find one around, or have the $$ to buy one
