| | | Forums66 Topics128,049 Posts1,055,701 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17988 08/06/2002 9:40 AM | Joined: Aug 2002 Posts: 3 Junior Member | | Junior Member Joined: Aug 2002 Posts: 3 | I RECENTLY BOUGHT A 49 CHEVY PICKUP FOR PARTS. I AM CURIOUS IF THE BLOCK OF A 216 AND THE 235 ARE THE SAME SIZE. BECAUSE THE ENGINE THAT IS IN THE 49 HAS A CRACKED BLOCK AND I NEED A REPLACEMENT BLOCK FOR IT. PLEASE TELL ME IF YOU KNOW ANYTHING ABOUT IT. | | |
#17989 08/06/2002 1:08 PM | Joined: Apr 2001 Posts: 39 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 39 | dead give away look on the passanger side of the block .if the side cover comes up around the plugs it is a 216 .if it does not go past the top of the block it is a 235 iy will be easy to tell the differance
47 Chevy COE..52 TO 30
#17990 08/06/2002 3:54 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Articles on this are in the tech tips.
Fred 52 3600 69 C-10
