3 members (stlcardinalsguy, baldeagle, Peggy M), 40 guests, and 6 robots.
Topics128,012
Posts1,055,317
Members48,419
#17984 12/13/2001 3:42 AM
Onmy t-5 it is an electronic speedometer. What should i do to use the stock speedometer. or is it going to be a lot of money to convert it.
thanks mike
#17985 12/13/2001 4:26 AM
go with aftermarket gauges, and the speedo's will use either.
May the force be with you - SoloWookie
solowookie.com
#17986 12/13/2001 6:01 AM
According to a posting on the Inliners site, Abbott Electronics makes a gadget called Cable X that is fully programmable for using the electric tranny with the mechanical speedo. About $300.
Talk to a good GM shop, they just might have something made up for just such a change over. Who knows???
#17987 12/13/2001 12:14 PM
86 GMC fleet trucks (for a certain company) had 292 originally.They were retro-fitted with a 4.3 GM V-6 .The 4.3 was TB injected and had a computer.They had an adapter(inline)on the speedo cable for the computer to have a signal for proper operation of the updated system.
In your case, you have the sensor at the tranny where the old speedo gear was plugged in on the 85 and earlier trannys.You might try to find anearlier type tranny.It will be cheaper than going with an electronic speedo.
