1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 4 Junior Member | | Junior Member Joined: Feb 2005 Posts: 4 | Here's a stupid question but I'll ask it anyway. While rebuilding the front end of my 55 1st 3100 I noticed the center link isn't straight but instead has a uniform bow in it.Is this "normal"? If not, should I attempt to straighten it? Also, anyone have any suggestions for removing the ball studs on the various front end components? I've got all the replacement balls and sockets but can't unscrew old ball studs. | | | | | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | I had a slight bend in mine also, switched to the heavy duty 7/8" dia tie rod and modern type tie rod ends . there is an article in the tech section about removing the old ball type. old navy51................ | | |
