3 members (Paul Mullen, JW51, GrandpasJimmy), 96 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
#179518 05/06/2005 6:10 AM
Junior Member
Junior Member
Here's a stupid question but I'll ask it anyway. While rebuilding the front end of my 55 1st 3100 I noticed the center link isn't straight but instead has a uniform bow in it.Is this "normal"? If not, should I attempt to straighten it? Also, anyone have any suggestions for removing the ball studs on the various front end components? I've got all the replacement balls and sockets but can't unscrew old ball studs.
#179519 05/07/2005 1:36 PM
I had a slight bend in mine also, switched to the heavy duty 7/8" dia tie rod and modern type tie rod ends . there is an article in the tech section about removing the old ball type. old navy51................
