7 members (Otto Skorzeny, 1955 1 Series, Rusty Rod, baldeagle, dt235sd, Woogeroo, Hotrod Lincoln), 369 guests, and 3 robots.
Topics128,165
Posts1,057,087
Members48,463
Just a quick question to see how the issue of gasoline is addressed in our older vehicles. Does everybody add lead to their gasoline at each fillup? I have an old **** 8N tractor and give it a shot of lead as a treat now and again, but most of the time just use unleaded, and have never had a problem. My sons and I are beginning restoration of a 61 Apache. Thanks for any input.
Not quite as lean
Not quite as mean, but
Still a Marine!
You'll find tons of discussions on this specific issue. I've been using Chevron Plus (87 oct) for almost 20 years. Never have had a problem. Hopefully more will step in to give their $.02 worth.
cmayna
Craig
I think if it's been on lead for first part of it's life it's "coated" enuff to be ok for a long time - I've put over 30,000 miles on a 235 using unleaded and it's still fine [about 80,000 total now]
Any old truck that has been stored in a field for any length of time usually has plenty of lead.
54 3100 with 235
62 flatbed dump C60 with 261
Absense of lead *may* cause exhasut valves to wear a bit faster than they would with lead. Not much, but some. Since it's a mechanical lifter (I presume) you are checking clearances anyway, so no problem. So you wind up doing a vavle job at 40K instead of 60K. BFD. New valves are better alloy than old ones, so after a valve job you're good to go.
Skip the lead, enjoy the ride!
George
Remember too that lead did not come into common use untill the 50's so you might find like the model T's they never where designed for it.
Lead - specifically tetraethyl lead - first began to be used as an additive in the late 1920s, in the US. It was originally a mix-your-own kind of deal, but after a while folks noticed that handling it as a concentrate was unhealthy. By the late 30s and 40s, TEL was commonly available in gasoline pretty much all over the US.
Cheers!
George
