1 members (Gdads51),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17927 10/10/2004 11:21 PM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | Just changed my transmission fluid to Redline Synthetic on my 1950 3/4. It runs great! However, now I have what appears to be a leak from the front of the transmission. I originally thought rear main seal but this is running down the front of the tranny and along the bottom. Is the seal just out or does anyone think the synthetic would cause this? | | |
#17928 10/11/2004 1:12 AM | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | I don't think a fluid change would cause it, not unless you did something totally weird like used ATF instead of 90w. I've learned to accept and embrace the rear main seal leak in my '52.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | |
#17929 10/11/2004 1:44 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | I use Redline gear oils,they tend to seep slightly where a mineral gear oil might not in vintage trannys. 3 and 4 speeds like yours don't have oil seals, just oil slingers, I don't think the synthetic slings as well as regular gear oil.The oil may be seeping past the front retainer to case gasket or the tranny is overfilled slightly.Check the lube after a ride when it's warm and expanded in volume. | | |
#17930 10/11/2004 1:52 AM | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | could be your fluid level may be to hi it will stop when it gets to the right level | | |
