3 members (55shaker, Bill Hanlon, FAST55), 72 guests, and 4 robots.
Topics128,056
Posts1,055,803
#17927 10/10/2004 11:21 PM
Just changed my transmission fluid to Redline Synthetic on my 1950 3/4. It runs great! However, now I have what appears to be a leak from the front of the transmission. I originally thought rear main seal but this is running down the front of the tranny and along the bottom. Is the seal just out or does anyone think the synthetic would cause this?
#17928 10/11/2004 1:12 AM
I don't think a fluid change would cause it, not unless you did something totally weird like used ATF instead of 90w. I've learned to accept and embrace the rear main seal leak in my '52. wink
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
#17929 10/11/2004 1:44 AM
I use Redline gear oils,they tend to seep slightly where a mineral gear oil might not in vintage trannys. 3 and 4 speeds like yours don't have oil seals, just oil slingers, I don't think the synthetic slings as well as regular gear oil.The oil may be seeping past the front retainer to case gasket or the tranny is overfilled slightly.Check the lube after a ride when it's warm and expanded in volume.
#17930 10/11/2004 1:52 AM
could be your fluid level may be to hi it will stop when it gets to the right level
