1 members (Eisenholtz), 59 guests, and 3 robots.
Topics128,022
Posts1,055,377
Members48,422
#179167 05/14/2005 5:23 AM
Junior Member
Junior Member
Are there VIN Plates anywhere else besides in the cab in a 49' 1/2 ton? I'm looking at a project truck and the one in the cab is pretty well worn and I can't make all of the numbers out.
Thanks in advance.
#179168 05/14/2005 7:32 AM
FOUND AT THE TOP OF THE PAGE "TECH TIPS" The simple answer is NO. You may be able to get some info off of the tag by taking a pencil and rubbing it accross the tag, then wipe it off. This method fills the indentations and makes it more legible to read. Good luck.......g
#179169 05/14/2005 1:25 PM
Moderator
Moderator
Another trick is to try using a flashlight or shoplight and shine it on the plate from different angles. This will often help you read it by casting shadows into the indentations.
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
#179170 05/14/2005 4:02 PM
Does the truck have a title? If not make sure you understand the process required to get one before putting much time or money into the truck.
