0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 14 New Guy | | New Guy Joined: Mar 2005 Posts: 14 | Hi folks, I am a novice, need some guidence. I have a chevy one ton, 1955, model 3800, with a six cyl. Have been running it for three weeks and no starting troubles till today. The floor starter looks like original equipment. I checked the ignition switch wires, seem to be tight and connected, no loose wires there. The starter looks like original equipment, but looks like there is a replacement switch on top. Shiny and clean condition. Not knowing exactly what to do, I turned the fan manualy then tried to start, no luck no ignition noise, no clicking, just no sign of life. There is power, lights and horn are working full power. Any suggestions? Thanks, WoodChips.
WoodChips
| | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | Give the starter housing a series of moderately-firm taps with a ballpeen hammer, where the housing steps down to a smaller diameter near the back. Then try the start pedal. If that makes it work, pull the starter and have somebody put a new set of brushes in it, or buy a rebuilt starter. It sounds like the brushes have worn too short and tapping with a hammer will re-seat them temporarily. Don't count on it working too often, though! Jerry
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Another thing to look at is the switch on top of the starter. Make sure the linkage is hooked up and that it is pressing it down far enough to make the connection inside. The switch itself may be bad. | | |
