| | | Forums66 Topics128,149 Posts1,056,817 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | does this include 1940 suburban the J C series? What year are body parts doors - fenders ect the same as 40 sub? Is it like 37 to 44 as the later 47 to 54 a lot of stuff is the same?  thanks Bill | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | A JC would be a '39 1/2-ton. Shares some parts with a 1940 (KC) and a few even fit from '39-'46. | | | | | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | Barry would a 39 panel be a J.C series I am looking at a rear fender for my sub and the one I am looking at is to narrow for a pickup , but the guy thinks it is a J C series fender? Would a 39 sub or panel rear fender be the same as a 40 sub? thanks Bill | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Yep Bill, a '39 1/2-ton anything would be a JC. The J stands for 1939 and the C is a 1/2-ton. Includes pickups, panels, Subs, Canopy Expresses and anything else rated at a 1/2-ton. The rear fenders would be the same from '39-'46. Make sure the fender is for a 1/2 or 3/4 ton for sure and not the larger 1 or 1-1/2 ton panel with 20" tires.
By the way, pickup fenders bolt flat to the box sides and panel fenders bolt up into the fender opening on the body like a car fender does. Hard to confuse them if you remember that. | | | | | Joined: Jan 2004 Posts: 17 Junior Member | | Junior Member Joined: Jan 2004 Posts: 17 | Barry I thought the 39 raer fenders were narrower than the 40 to 46, because the bed is a different width Diego | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | '39 pickup rear fenders are about 1-3/8" wider than '40-'46 pickup rear fenders due to the difference in box width. Bill is looking at a fender for his '40 Suburban, which uses a different fender than the pickup. The Sub./panel/canopy express rear fenders are the same from 1939-46. What you have to watch out for is there are many NOS panel truck rear fenders floating around from 1937-46 BIG panel trucks with 20" tires. These are pretty common (the military maybe stocked a ton of them?), but do not fit the 1/2 and 3/4 ton panel trucks. The bigger panel fenders are longer and have a larger wheel opening. I bought a couple big panel truck fenders before I learned.  | | |
