| | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17871 12/29/2001 6:59 PM | Joined: Dec 2001 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 34 | I just put my newly rebuilt 250 into my 66 c10 and the universal is 3/4 inch to far away from the yoke coming out of the 4 speed "granny" trans. I don't know how this happend nor what to do about it. The engine and trans mount bolted right up to were they go so I don't see how they could be off or where to get the extra 3/4" I need to hook up the driveshaft | | |
#17872 12/29/2001 7:50 PM | | Anonymous Unregistered | | Anonymous Unregistered | Sandcaster,
Doesn't the driveline have a spline joint in it? Or the tranny has a splined yoke on the back of it . . . either way pull on the splined joint and the U-Joint should bolt right up. If it doesn't slide (telescope) easily, you should disassemble, clean and grease. | | |
#17873 12/29/2001 10:44 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Slots! There are small slots in all mount points. On engine, trans, and most of all the mid-ship bearing to allow some adjustment or less tolerance in alignment when assembling on the plant line. I take it you did not remove shaft first and pulled engine and trans out as one peice? Anyway, loosen the mid-ship bearing at it's mount on x-over and it should move enough maybe. The slip joint is usually only on the last part of driveshaft and front part stays still. May have to loosen engine and trans mounts and try to slide it back a little. Won't be much for sure!
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#17874 12/30/2001 2:48 PM | Joined: Dec 2001 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 34 | Thanks guys, Once again this site has provided answers I desperaely needed. Thanks for taking the time to answer this post  | | |
