| | | Forums66 Topics128,079 Posts1,056,310 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 81 | I am about to replace all four of the original wheel cylinders on my 62 1/2 ton short bed chevy truck. I seem to recall problems with getting the front wheel cylinders off. Could someone provide me with technical tips on how to go about this job?? Thanks in advance!!
Green Machine
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | After you remove the brake shoes loosen the flare nut on the back of the cyl. Remove the 2 bolts holding the cyl. to the backing plate. Unscrew the flare nut. If it is froze to the tube dont twist the tube but pull the cyl. out far enough to turn it around & screw it off. Heat the nut to a soft glow & than turn the nut. It is best to put a kit in the master cyl. & bench bleed it before putting it back on.If you need more help post a reply. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2001 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 81 | Thanks for the advice Wrenchbender! I will take a shot at the job as soon as the showers let up. I recently replaced the master cylinder so a good bleeding should do the job after I get the cylinders and shoes replaced. I am using softer brake linings to increase my stopping power. Since I am still without power brakes every little bit helps.
Green Machine
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Don,t let the master cyl go reservoir run out of fluid while you have lines unhooked. That is what makes it real hard to bleed. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
