| | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Hello, I've got my steering column from my 77 GMC 1/2 ton and was wondering if it would fit in my 49 GMC 1/2 ton? What type of modes will I have to do, and is there a kit I can by to hook up the tranny linkage? Thanks.
kskt4 | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Never done that swap but with any such change you will have to put it in place and figure it out. Learn by doing and then let us know how you did. | | | | | Joined: May 2005 Posts: 10 Junior Member | | Junior Member Joined: May 2005 Posts: 10 | that is the same column that I see in most of these trucks that have been redone. You can get some chevy van columns that are the same but don't have the ignition on the column, that way you can put your key back in the dash, looks cool. | | | | | Joined: Jan 2000 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 175 | My 67 Malibu has a nice tilt column with shifter but no key. I always thought an identical one would look awesome in my '46.
Gravity - It's not just a good idea, it's the law.
| | | | | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | I was at a car show on friday, A guy had a 55 chevy pick-up with a late model column and kept the stock 55 steering box. He cut the shaft on the stock box about two inches from the box and used a borgenson U-joint to connect to the new column, It was a nice looking job. old navy 51.............. | | |
