0 members (), 107 guests, and 2 robots.
Topics128,265
Posts1,058,365
Members48,485
#178543 05/26/2005 7:19 PM
Hello,
I've got my steering column from my 77 GMC 1/2 ton and was wondering if it would fit in my 49 GMC 1/2 ton? What type of modes will I have to do, and is there a kit I can by to hook up the tranny linkage? Thanks.
kskt4
#178544 05/26/2005 7:23 PM
Anonymous
Unregistered
Anonymous
Unregistered
Never done that swap but with any such change you will have to put it in place and figure it out. Learn by doing and then let us know how you did.
#178545 05/27/2005 3:34 AM
Junior Member
Junior Member
that is the same column that I see in most of these trucks that have been redone. You can get some chevy van columns that are the same but don't have the ignition on the column, that way you can put your key back in the dash, looks cool.
#178546 05/27/2005 4:40 AM
My 67 Malibu has a nice tilt column with shifter but no key. I always thought an identical one would look awesome in my '46.
Gravity - It's not just a good idea, it's the law.
#178547 05/28/2005 2:19 PM
I was at a car show on friday, A guy had a 55 chevy pick-up with a late model column and kept the stock 55 steering box. He cut the shaft on the stock box about two inches from the box and used a borgenson U-joint to connect to the new column, It was a nice looking job. old navy 51..............
