| | | Forums66 Topics128,106 Posts1,056,214 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | Thanks for all the ideas on the fuel tanks guys. Man, thats a lot of ideas for this hillbilly. Now, how about some ideas on some factory installed a/c heater units i could convert to install in my 64? This is the only site that understands what its like to use salvage parts. Thanks for all the help. Now if I could just figger out how to e-mail you a pitcure of my truck. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Before I found a factory a/c unit I was thinkin hard on adapting an S-10 unit up behind the dash. My buddy has a scrapped 2000 & the box looked like it would fit, losing most of the glove box tho. Brian | | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | Haven't done the actual measuring and planning, but I am figuring on using chunks of the firewall out of my '89 Chevy parts truck to get the heat/ac guts and the pedal assemblies.
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I found a 60's aftermarket under-dash A/C that I'm going to use, in combination with a factory fresh-air heater. I think it will work fine. | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | Have thought about taking the under dash unit out of a older jeep wagoner and put it in my 53 3100. its a complete unit will have to trim it down but i think it will work fine | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | Wait wait wait. My 64 doesn't (and didn't come with) factory A/C, and heat. You're saying you can get one out of a junkyard (which I go their all the time) and put it in? What about the vent openings, or were there any? I didn't even know you could do that!!!!! Thanks | | |
