3 members (Joe H, Gdads51, UtahYork), 99 guests, and 2 robots.
Topics128,264
Posts1,058,355
Members48,485
#17833 10/24/2004 2:35 AM
Howdy Guys!,,,I have a problem,on my 50,,,it used to run,now doesn't frown ,,when i put gas down the carb,,she'll run,,Burn the gas up,then Zero,,I even put gas down the gas tank too,,,Nothing,,Doe's it sound like the fuel pump is bad????,,Any help guys??? frown
#17834 10/24/2004 3:32 AM
Moderator
Moderator
Assuming that we know it has gas in the tank...
Sounds like a fuel pump or plugged filter to me.
Check the filters first:
Do you have an inline filter? Try removing it and blowing through it. Is is plugged? How about one of those little screen filters where the line comes into the carb? Remove it and see if it is plugged.
Then worry about the fuel pump:
Shadetree method: You could remove the output line from the pump and stick enough fuel line rubber tubing on it to run into a can, bottle or something, then crank the engine and see if you get any fuel out of it.
The right way: Don't the pro's use a device that they can connect to the fuel line that will measure pump pressure?
If all this fails, suspect the sock in the tank.
One other thing... If you are running gasahol it has a nasty habit of cleaning everything up, and dumping all that residue that it strips from the tank and lines right into the filters. Nice to have a clean fuel system, hard on the first couple of filters.
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
#17835 10/24/2004 5:40 PM
you can also try taking the input line to the fuel pump and dropping it into a jerry can of gas and see if it works then, if not then check for fuel comming out of the pump, may be an idea to pull all the plugs to make it easier on the battery when checking the pump. If the pump checks out ok then blow the fuel line from the pump back to the tank and add a fuel filter at the tank to stop the crud from getting back into the line.
