| | | Forums66 Topics128,269 Posts1,058,403 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17784 12/17/2002 4:42 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | I did the break-in on my 235 about two weeks ago. I left the oil I drained out of the motor sitting in the open drain pan until this past weekend. I poured it into my larger container I use for recycling. The break-in shavings and stuff had settled to the bottom of the pan, leaving a silvery shiny goo. Looks like a combination of tiny metal flakes from bearings, rings, cam & valvetrain, etc. No large pieces or ribbons, kinda looked like a very fine metal flake paint job on the bottom of the drain pan.
Is this normal? Im so paranoid about this new motor.
Car had 30 min break-in, then was driven around town once. Is now down for rear brakes. How long can a new engine be sat up without hurting anything? Does it hurt a new engine to let it idle to operating temp then shut it down?
Thanks chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#17785 12/17/2002 4:47 PM | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Hey, chip, at my work we sent off "oil samples" when we do regular oil changes on the bigger diesels (Cummins, Detroit, etc). Check with some local shops and see if you have a lab locally that analyzes this stuff. I'm not sure if metallic particles are normal-it's been a long time since the one and only engine rebuild I've done. Best of luck to you. Hope all comes out O.K. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
#17786 12/17/2002 4:49 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Sounds normal to me. I have always placed a small flat magnet near the drain plug for the first couple of oil changes( remove the magnet before draining oil/ reinstall with drain plug).
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#17787 12/17/2002 5:29 PM | Joined: Jul 2002 Posts: 59 Member | | Member Joined: Jul 2002 Posts: 59 | There's no difference between letting your "new" engine sit and letting an "old" engine sit -- same amount of wear on start up. Most wear on an engine is at start, especially if it's been sitting for a few days. I would rather let it sit for a few weeks and start it once, rather than starting it every few days. 72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
#17788 12/18/2002 7:43 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Like I said, I'm paranoid. Just wanted to make sure my engine wasn't chewing a bearing, or that letting it sit wouldn't hurt it.
thanks again
chip
#17789 12/19/2002 12:45 AM | Joined: May 2001 Posts: 1,908 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,908 | The Cummins in my '90 D***** truck has a magnetic oil drain plug. I suppose that's for inspecting for metal but it also will stick on the bottom of the oil pan when changing the oil. I've never seen a bit of metal on it but it only has 175,000 miles on it. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#17790 12/19/2002 2:42 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | We once blew a cylinder/piston on a VW that had seen a recent overhaul including bottom end. Instead of disassembling we cleaned it out real good and ran it for another 100,000 miles. I did put in a magnetic plug and every oil change there was gobs of metal.
In your case I would also be a little worried with visible metal. Is it really metal? Hold a magnet to it.
54 3100 with 235 62 flatbed dump C60 with 261
#17791 12/19/2002 3:55 PM | Joined: Aug 2001 Posts: 139 Member | | Member Joined: Aug 2001 Posts: 139 | Chiphead, can you post a picture? If you can get it in bright sunlight, you will be able to see the different metals. I would investgate this till I knew for sure if it's a problem or not. I would guess you do have problem. If it has a spin-on filter, you can use a large pipe cutter to open the filter. Screw a short pipe into the filter and chuck it up in a vice to cage it. After the can is off cut the pleats away from the base and stretch out the pleats. Larger chunks should be there. Laying the paper, at a slight angle to drain the oil off, in the sunlight will show any metal particals. You could do this with a filter off a known good engine to compare. Good luck. Mike | | |
#17792 12/20/2002 7:40 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | I know its worrysome but try to not obscess over this fact of life with any new engine. The first 3-4 oil changes every couple of hundred miles you will see shiny stuff suspended in the oil. If it starts easiely, runs and with good oil pressure you are very lucky the machinest knew enough to put the cam bearings in correctly.
52pu
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
