1 members (klhansen),
107
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,856 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 113 Member | | Member Joined: Apr 2005 Posts: 113 | I need to narrow the tierod on my 48 3100 because I recenlty put in a dropped axle. Does anyone know what kind of thread it is? Is it standard 3/4 pipe thread? | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | rsg2506 - It could be a 3/4 pipe thread. :confused: If it is, I would be interested in knowing. I never thought of a 3/4 pipe thread when I was trying to shorten my tie rod and I never could find a thread that worked. :mad: A 3/4" nut will screw on to the end of the tie rod, but it's probably closer to a 13/16" thread, but I could never find a 13/16" die. If it was me, I would get my hands on a female 3/4" pipe nipple  and see if it would screw onto the tie rod. Good luck!! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Not pipe thread as pipe thread is tapered. Probably 25/32"-16, which is an oddball thread that you will have a hard time finding a tap for.
You bent your steering arms in to clear the tires, and that's why you need to narrow the tie rod? Maybe you could make a new tie rod using some more common sized tie rod ends? Just an idea. | | | | | Joined: Nov 2004 Posts: 2,404 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,404 | You will need to measure the outside thread diameter to know for sure. Using calipers or a micrometer, it should measure slightly less than the decimal equivilant. 3/4 (.750) could be as small as .740. You will then need to count the number of threads per inch. 3/4-10 (10 threads per inch is coarse) 3/4-16 (16 threads per inch would be a fine thread). There is an almost infinite number of thread combinations that can be machined. I would guess that you have a typical fine thread (or SAE) as some would call it. I would have to agree with Barry. It is unlikely that it is a pipe thread, as this type of thread is designed to bottom out (on the taper) to form a seal.
J Lucas
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Apr 2005 Posts: 113 Member | | Member Joined: Apr 2005 Posts: 113 | Thanks for the feedback guys. When they dropped the original axle, it moves the king pins inward about an inch on each side due to the stretch. I'll take a micrometer and see what the diameter is and check the threads per inch. Hopefully it's not an oddball size. I've read a few other posts where another member shortened his original tierod, so I'm hoping the thread is somewhat common. I've already ordered the newer style tierod ends from Chevyduty, so I'd like to use the existing tierod. | | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | Right hand thread AND left hand thread. Reassess your problem. I'm thinking your friendly local machine shop could do that job for you for much cheaper than buying L+R hand dies of oddball sizes that you will never use again.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Apr 2005 Posts: 113 Member | | Member Joined: Apr 2005 Posts: 113 | Cosmo, Thanks for the tip. You may be right. Is there a reason I would need to shorten both sides of the tierod? It seems like I could just cut off the right hand thread side, shorten and rethread it? If it's a standard 3/4-16, they cost about $7. I think if it's an oddball thread, the machine shop is probably the better way to go.
Thanks again, -Rich | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | It's definitely not a 3/4 pipe thread. I check that out last night. I've been through this situation myself and engaged the help of Barry Weeks at the time. Between the two of us - mostly him, we found no dies available that are that thread size and you can totally forget the the left hand thread. You probably could find a LH thread at an old shop somewhere or a fully equipped shop. It's such an odd thing, they are difficult to find. Finally, we cut off the RH thread end and re-threaded it with a 3/4-16 die. It worked fine. About the only other thing you can do is cut the tie rod somewhere in the non-threaded area, remove the a portion and weld it back together to the length you need. I think we all would be interested to hear if you do come up with the dies you need and/or what you end up doing!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Joe, I would love to find some left and right hand taps and dies in that 25/32"-16 size. I go to alot of machine shop auctions and stuff and someday I just know I'll find a whole box full sitting on a shelf gathering dust, and I'll be the only bidder at a $1.00!
If you can't find a die to rethread the RH side, I think the cutting and welding idea would work good. Cut, grind a large "v" groove in it, and weld or have a good welder weld it if you can't. Before welding, find or make a pipe-like sleeve (maybe 6" long) to slip over the welded joint after it's done, and then weld each end of this sleeve onto the tie rod to reinforce the joint. | | | | | Joined: Apr 2005 Posts: 113 Member | | Member Joined: Apr 2005 Posts: 113 | I measured tonight and the threads are 3/4-16. I had a 3/4-16 tap on hand and it ran into the tie-rod ends without a problem. I'm going to pick up a 3/4-16 die and I'll update when I get everything in place. Thanks for all the help guys.
-Rich | | | | | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | Way to go rsg!! Nice solution Barry.
