go to home depot or where-ever and get some epoxy putty,, if you can get to the crack or brk this will probably do, I use it all the time being that I am not a welder,,have my tail pipe put back together with this stuff and it is still holding, this was over 2 yrs ago,, I use it all the time, just a putty type of clay,, peel off what you need, rub it together , put it on what ever leaks or needs sealing, or broken, it gets hard in about 5 min,, should work,, let me know,,,Fred
