1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 108 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 108 | I have a 46 Chevy 1.5 ton with a 235 and a Rochester Carb. My question is where or how do you hook up the throttle linkage? The choke was easy but am scratching my head on the throttle. A real live picture would be most helpful. Timmer | | | | | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | This was discussed a while back and some good pictures were provided. Do a search and you should be able to find it. If you can't find it I can take some pictures of mine for you.
1948 3600 thriftmaster
| | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | Wasn't Dolly Parton born in Throttle Knob ?
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Too bad all the info in the lounge is lost. It may have been discussed in there.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | WHAT LOUNGE??? The cable should hook to the side of the throttle linkage where the throttle plate is, near the bottom of the carb,,, not the choke at the top of the carb...
| | | | | Joined: Jul 2003 Posts: 85 Member | | Member Joined: Jul 2003 Posts: 85 | I just took my rochester off my 216, I have pics of the linkage if you want them. PM me and I can e-mail them tommorrow. (they are not the best pics in the world, just good enough for me to see what I took off.
-Mike R. | | |
