1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 144 Member | | Member Joined: Dec 2002 Posts: 144 | Hello! Just wanted to know if any of you had any info on a good "Steering Wheel" Restoration Company near Virginia,Carolinas or on the Eastern Coast?
Thanks for the help! Classic Finn | | | | | Joined: Dec 2002 Posts: 144 Member | | Member Joined: Dec 2002 Posts: 144 | There is supposed to be one in North or South Carolina but can anyone tell me the Name and Adress of it? Classic Finn | | | | | Joined: Jan 2005 Posts: 279 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 279 | Automotive Specialties 857 Nine Times rd. Pickens,SC,29671 1-800-676-1928
Gangster whites and straight pipes.....
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Classic Finn, did you get my messages? E-mail me when you get a chance please. Thanks.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Feb 2000 Posts: 987 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 987 | Hey fin what about doing it yourself. I mean if it just has cracks in it? use some epoxy to fill the cracks and the sand smooth. prime and paint. I have yet to do mine but this is what I am planing on doing. I figure if I screw it up I will just go down to the local Chilli's restuarant and buy the chevy stering wheel that they have hanging on their wall.
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Nov 2004 Posts: 170 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 170 | I just finished restoring mine and I'm very happy with the results. I just couldn't see spending $250 to have someone else do it. I do have a number for someone in California. Found this guy at the Pomona show: Koch's Steering Wheel Restoration 26911 N. Furnivall Ave. Canyon Country, CA. 91351 phone: 661-252-9264 I saw his work and it looked good. 4 what it's worth... | | | | | Joined: Dec 2002 Posts: 144 Member | | Member Joined: Dec 2002 Posts: 144 | Hello Folks! I would do the wheel myself, (except) This is an old 1937 BANJO WHEEL which does not have the so called Eurathane or Plastic any longer. It has the nice Banjo Center, Other than that its the STEEL thats left! UGH! If anyone knows how to pour the eurethane and where to get a mold..??? Then Id sure give it a shot. All the best Ol Classic Finn | | | | | Joined: Jan 2005 Posts: 279 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 279 | In this case I would not try it myself.I am not sure if Kotch recasts steering wheels,he was not doing it the last time I saw him(10 years ago).This is the guy that has done some for me.He does excellent work. www.qualityrestorations.com
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Eastwood sells a book that describes how to fix your problem. Basically, you find a standard hard rubber steering wheel, cut the rim off, weld the banjo center to the rim, then re-do the plastic over the welds with filler or epoxy. | | |
