5 members (Phak1, Otto Skorzeny, mo2cyl, Greg_H, dt235sd), 87 guests, and 2 robots.
Topics128,049
Posts1,055,546
Members48,425
#177362 11/21/2004 7:40 PM
Have a '58 235 in the 55.1 pickup I recently purchased. When fully warmed oil pressure drops to 0 at idle. Line from top of filter goes to rear of engine (oil pressure t-fitting); lower line goes to forward location. Any suggestions?
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
#177363 11/21/2004 7:51 PM
Riding in the Passing Lane
Hook a master gauge to it & see if it agrees with
the dash gauge. The oil filter is hooked up correc
ly. Plug off the line going in & see if that
changes the pressure. If its still low you have
serious engine problems. Try useing a heavy weight
oil. smile
1972 Chevy c10 Cheyenne Super
#177364 11/21/2004 7:51 PM
Sounds like it is shot.. dump the 235 and put in a 283, they dont need oil pressure.
My opinion on this, weak as it might be, is that there is air in the oil pressure gage line.... when the actual engine oil pressure drops below the pressure of the air in the gage line, it equals out and the gage pressure drops to or near zero... the engine should still be getting some oil to it, otherwise it would sieze up...
Another quality post.
Real Trucks Rattle
#177365 11/22/2004 3:25 AM
I think it indicates worn bearings. Are you running straight 30W oil? Mine does it when I come off the freeway. But not during city driving.
54 3100 with 235
62 flatbed dump C60 with 261
