11 members (TexasJim50, cmayna, Hotrod Lincoln, WICruiser, Chip O, KCMongo, Jaison, Donf, Woodcmiami, Bill Hanlon, MNSmith),
78
Mod | | | Forums66 Topics128,032 Posts1,055,523 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | Have a '58 235 in the 55.1 pickup I recently purchased. When fully warmed oil pressure drops to 0 at idle. Line from top of filter goes to rear of engine (oil pressure t-fitting); lower line goes to forward location. Any suggestions?
cgresham1212 If you don't drive it, why have it? 55 1st Series 3100 5 window
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Hook a master gauge to it & see if it agrees with the dash gauge. The oil filter is hooked up correc ly. Plug off the line going in & see if that changes the pressure. If its still low you have serious engine problems. Try useing a heavy weight oil.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | Sounds like it is shot.. dump the 235 and put in a 283, they dont need oil pressure.
My opinion on this, weak as it might be, is that there is air in the oil pressure gage line.... when the actual engine oil pressure drops below the pressure of the air in the gage line, it equals out and the gage pressure drops to or near zero... the engine should still be getting some oil to it, otherwise it would sieze up...
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I think it indicates worn bearings. Are you running straight 30W oil? Mine does it when I come off the freeway. But not during city driving.
54 3100 with 235 62 flatbed dump C60 with 261
