1 members (Peggy M), 95 guests, and 1 robot.
Topics128,101
Posts1,056,182
Members48,436
#176991 05/27/2005 3:29 PM
Do 55-59 3/4 ton dually have 1ton rear ends?
I heard that 3/4 ton dually are equipped with 1 ton rear ends from the factory.
#176992 05/27/2005 4:09 PM
A 3/4 ton with dual wheels? Was that a factory option? I believe the center section is the same, but the hubs and brakes might be different to accomodate the dual wheels. My 59 1-ton has much bigger brakes than a 3/4 ton, enough that 16" wheels won't fit. It needs 18" wheels to fit over the drums.
#176993 05/27/2005 9:02 PM
If there is a difference between the H052 and the H070 axle, I haven't found it yet.
1954 GMC De Luxe COE
#176994 05/27/2005 10:10 PM
Junior Member
Junior Member
Brake size and gearing options were about the only differences between 3/4 and one ton axles.
#176995 05/27/2005 10:41 PM
So are 3/4 2 wheel axel cylinders the same as 3/4 ton dually wheel cylinders?
