3 members (oldsteve, doyle1950, frogfarmer), 167 guests, and 0 robots.
Topics128,087
Posts1,055,974
Members48,430
Junior Member
Junior Member
I would like to get a good assement of the Engine and Trans of a new 49' half ton. It appears to be a 235 with a 4 speed. Is there a good way of knowing what kind of shape the transmission is in, besides putting a good motor in it and driving it? Is there a good source for rebuild 235's. I was considering rebuilding it myself but have never done it before. How hard is a rebuild going to be for a guy that has never rebuilt and engine before? Sorry for all the questions, just want to do my homework before I start tearing stuff apart.
Gavin,
What 235 are you running? The 54-62 or the splash oiled variety?
What do you want to do with this truck?
If the engine is already out of the truck and is a full oiler 54-62 235, I would buy a book or two and give rebuilding a try. The machine shop will do your block and head work. But all of the parts and work will still cost you some money.
As far as the tranny goes, if you are building a daily driver, drop in a GM T-5 out of an S-10 and a different rear end and increase the speed of your ride. If you are going for stock, you could try a tranny shop to take a peak inside to see how your gear box looks.....
Lots of options depending on what you want to spend. If you have the $$ someone out there can do almost anything you want....
Junior Member
Junior Member
Not sure which 235 it is. I'm pretty sure it is not the splash oil kind, how do I tell? I have read about the S-10 trans, and that looks like a good option. I assume they are pretty easy to come by. Does this transmission just fit with this engine, or is there specialty stuff to make it work. I would like to have a daily driver. I am doing a ground up restoration so this is going to be done over a few years. What does machine shop work run for something like this?
Does your valve cover have the two nuts on the top holding it on or 4 around the outside with no nuts on the top?
If you find the # near the dipstick and post that on here, someone will be able to tell you what engine you are running.
If you have not checked the tech tips section above, there are a couple of articles on the T-5. Here in MN, the T-5s are hard to come by. I have a line on one but have to figure out a way to get it....truck is heading for the crusher...I can't buy the whole thing....hopefully the tranny can come out before it goes to China.......
Someone may have diffent opinions....but you will spend the same if not more rebuilding your six than a V-8....I don't mean "build a V-8 instead"......just something to compare it to.
If your head has not been updated, good time to install the hardened seats and all that stuff..
Once again...money is the key.
