| | | Forums66 Topics128,014 Posts1,055,330 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | The sand blaster forgot to mask off the ID plate for my 52' on the drivers side door pillar. It's toast. Is there a way to replace this piece of history? Thanks  | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Chevy Duty sells them. Part #33-013 for $14.95. I'm sure other vendors have them as well. Be sure to buy the original type rivets at the same time.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I did the same on my jeep, and I had it engraved at a trophy shop with the vin. | | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | So by the plate from Chevy Duty and just have it engraved w/ the VIN # from my registration. Sounds easy enough. Will my pop rivet gun work in this application after I grind off the old rivets? | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Yep. Any engraving shop will be able to do it for you. The old style rivets have sort of a bubble in the center. You just tap it with a center punch an it will swell at the backside holding the plate on. No gun required. You can use your gun and regular pop rivets if you don't mind the look.
