11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible), 116 guests, and 1 robot.
Topics128,124
Posts1,056,347
Members48,441
#175983 04/03/2005 4:39 PM
Hi Guys,
I am slowing getting my 49 GMC 1/2 ton back together. I put on my front 5 bolt disc brake conversion kit and it looks great. It's a 4 1/2" bolt pattern. Problem is the rear end I have in is from a 77 GMC and it is a 4 3/4" bolt pattern. I was wondering if it is possible to change the axles to a 4 1/2" bolt pattern? If so, what donor do I look for? Or should I go new axles? thanks guys.
kskt4
Why not re-drill to the new size if axles and components are OK. Most welding/machine shops can do this for about the same price as getting another set of axles or less.
41 Chev 2dr coupe
51 3100 w/a 261
11 Camaro RS ragtop
