| | | Forums66 Topics128,088 Posts1,056,125 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 72 | Hi Guys, I am slowing getting my 49 GMC 1/2 ton back together. I put on my front 5 bolt disc brake conversion kit and it looks great. It's a 4 1/2" bolt pattern. Problem is the rear end I have in is from a 77 GMC and it is a 4 3/4" bolt pattern. I was wondering if it is possible to change the axles to a 4 1/2" bolt pattern? If so, what donor do I look for? Or should I go new axles? thanks guys.
kskt4 | | | | | Joined: Aug 2001 Posts: 44 New Guy | | New Guy Joined: Aug 2001 Posts: 44 | Why not re-drill to the new size if axles and components are OK. Most welding/machine shops can do this for about the same price as getting another set of axles or less.
41 Chev 2dr coupe 51 3100 w/a 261 11 Camaro RS ragtop
