2 members (baldeagle, homer52), 36 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#175921 05/25/2005 8:54 PM
1 Offline
what is the work involved with converting a longbed frame to a shortbed. i like the look of the shortbed better, but if it means spending hundredsof extra dollars, then i wont worry about it, but right now the only work i see involved is moving the mounting holes for the bed and shortening the frame and i know im probably oblivious to a lot of things so im sorry in advance haha. thanks.
63 Chevrolet Short Fleetside
64 Chevrolet Long Stepside
http://community.webshots.com/user/64stepside
#175922 05/25/2005 9:01 PM
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=002012
I have asked the same question , maybe this will help , cheers
Jan from Belgium
Don't waste water, drink wine !
1946 Chevrolet 1/2-Ton Truck
#175923 05/28/2005 10:03 PM
1 Offline
well that helped some but i really need to know exactly what work is involved in shortening the frame and whether or not i need to redrill different mounting holes for suspension or brakes or if i need to relocate things and stuff like that.
#175924 05/28/2005 11:29 PM
64bowtie - you cut a section outta the frame between the back of the cab and the front hanger of the rear spring - try to pick spots away from any cross members and make an angled or 'stepped' cut, so the weld isn't straight around the C channel - can be done so the only holes you may need to drill will be for bed mounts - hafta run new brake lines to the rear [shorter!] and get the e-brake cables for a shortbed - also may need to nip the rear of the rails a bit, I fergit easy these days grin
#175925 05/29/2005 6:42 PM
1 Offline
thanks a lot red. im gona go take a look at the frame and crap haha.
#175926 05/31/2005 1:06 AM
1 Offline
if i shorten it, do i have to shorten those braces mounted underneath the back of the cab that support the suspension underneath the axle?
#175927 06/03/2005 1:19 AM
1 Offline
the arrows point to the brace things i was talkin about. sry for the bad pic my cameras out of batteries grr.
#175928 06/03/2005 1:23 AM
1 Offline
the arrows in the pic from the link below point to the brace things i was talkin about. sry for the bad pic my cameras out of batteries grr.
http://classictruckworld.tenmagazines.com/gallery/64stepside/82843.jpg
