1 members (stlcardinalsguy),
71
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 61 Member | | Member Joined: Aug 2004 Posts: 61 | what is the work involved with converting a longbed frame to a shortbed. i like the look of the shortbed better, but if it means spending hundredsof extra dollars, then i wont worry about it, but right now the only work i see involved is moving the mounting holes for the bed and shortening the frame and i know im probably oblivious to a lot of things so im sorry in advance haha. thanks. | | | | | Joined: May 2005 Posts: 96 Shop Shark | | Shop Shark Joined: May 2005 Posts: 96 | http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=002012
I have asked the same question , maybe this will help , cheers
Jan from Belgium | | | | | Joined: Aug 2004 Posts: 61 Member | | Member Joined: Aug 2004 Posts: 61 | well that helped some but i really need to know exactly what work is involved in shortening the frame and whether or not i need to redrill different mounting holes for suspension or brakes or if i need to relocate things and stuff like that. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 64bowtie - you cut a section outta the frame between the back of the cab and the front hanger of the rear spring - try to pick spots away from any cross members and make an angled or 'stepped' cut, so the weld isn't straight around the C channel - can be done so the only holes you may need to drill will be for bed mounts - hafta run new brake lines to the rear [shorter!] and get the e-brake cables for a shortbed - also may need to nip the rear of the rails a bit, I fergit easy these days Bill | | | | | Joined: Aug 2004 Posts: 61 Member | | Member Joined: Aug 2004 Posts: 61 | thanks a lot red. im gona go take a look at the frame and crap haha. | | | | | Joined: Aug 2004 Posts: 61 Member | | Member Joined: Aug 2004 Posts: 61 | if i shorten it, do i have to shorten those braces mounted underneath the back of the cab that support the suspension underneath the axle? | | | | | Joined: Aug 2004 Posts: 61 Member | | Member Joined: Aug 2004 Posts: 61 | the arrows point to the brace things i was talkin about. sry for the bad pic my cameras out of batteries grr. | | |
